Re: Siemens dishwasher extraklasse hydosensor fd8009 26261gb
Martin wrote:
Enzs1 wrote:
Thanks Martin, No lights come on the control panel at all ?
Ah I see, then that would suggest to me the actual control unit (part no: 00268594 cost £98.18) is at fault. 😕
Perhaps a close inspection of the actual circuit board might be an option if you’re up for it? Dry joint maybe?
Thank you Martin will attempt to identify a dry joint, if not successful, then go with the purchase of a control unit. Can you guide me further on where best to buy the part? Much appreciated
