Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Siemens Dishwasher faults
- This topic has 11 replies, 3 voices, and was last updated 12 years, 5 months ago by
Beau55.
November 8, 2013 at 12:45 pm #78000
Beau55
ParticipantSeimens Hydrosensor Dishwasher stopped working. Showing 199 on clock and trying to drain but is empty. Will not reset through power off and on again. Also diagram on clock showing circulation. Auto and 35 degrees button still lite. Any thoughts, tests or reset sequence ?
November 8, 2013 at 1:00 pm #404137don
ModeratorRe: Siemens Dishwasher faults
ENR number and FD required please in order for someone to be able to help. These are usually located just left of centre on the top door edge printed onto the metal.Don
November 9, 2013 at 7:03 pm #404138Beau55
ParticipantRe: Siemens Dishwasher faults
Believe numbers are as follows
ENR SE24A230GB/17
FD 8210 960026November 9, 2013 at 7:47 pm #404139Martin
Beau55 wrote:Any thoughts, tests or reset sequence ?
Well firstly try to reset the programme by pressing both the 1st and 3rd programme buttons together whilst the machine is switched on. Then shut the door and it should drain for 60secs then switch off.
One question: If you turn on the on/off switch with the door open does the drain pump still run?
November 11, 2013 at 10:17 pm #404140Beau55
Tried to reset but it did not stop after 120secs. Machine starts after very short pause when switched on with door open or not. no difference closing and opening door during this trial. First and third buttons are lite when switched on and go out when pressed together for the reset
November 12, 2013 at 8:41 am #404141Martin
The moulded base of the appliance is flooded. The water needs draining from it before it will function normally. Then you will need to find out what caused the leak inside?
November 12, 2013 at 10:17 am #404142Beau55
No water in moulded base only inside, in sump area and a very small amount.
November 12, 2013 at 4:17 pm #404143Martin
If the pump works with the door open then the base anti-flood switch has been activated.
November 12, 2013 at 7:11 pm #404144Beau55
Disconnected both micro switches and checked switching function. both OK. Tried resetting with both detached but no joy. Assume default to pump when disconnected. Still pumping out door open or not. Any other resetting tips for the anti flood switch. Seems to function ok. Clock not showing full 199 when disconnected.
November 12, 2013 at 7:41 pm #404145Martin
Time to take a close look for damaged surface components on the PCB now. 🙁
November 12, 2013 at 8:20 pm #404146Beau55
I assume the PCB is behind the door and part of the programme, clock, buttons etc
November 12, 2013 at 8:48 pm #404147Martin
Yes…!
