Siemens dishwasher SE23H160AG/01 no power
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens dishwasher SE23H160AG/01 no power
  • #103445
    el.mag18@gmail.com
    I will be very grateful for any advice regarding our Siemens SE23H160AG/01 which has no power.
    I tried unplugging it & pressed power & reset buttons but it has no power.
    Previous night it worked but there were no lights on the panel & today there are no lights & no power & no error codes.
    The socket is ok & plugging it into another socket does not change things.
    10 A fuse has continuity with Multimeter.
    imeter.The door closes with nice clunk.
    I opened the panel & there are no burnt or loose wires. I have attached the pics.
    Is there another fuse in the dishwasher? The non-contact tester shows power coming into the cable but not in the panel.
    I will be grateful for any suggestions to trouble shoot & get it working.
    Many thanks
    #493178
    the power board is at the rear right. the power cable plugs straight into it
    the voltages on the front panel are mostly low voltage for the circuit boards
    el.mag18@gmail.com
    Thanks, will check it out.
