Went to a Siemens dishwasher SE24207gb/01 today, reported leak from door. This is the common bosch type with plastic base but has a mech timer unlike most. Sat and watched, no leak, then on a hot rinse the motor sped up
and water came out the door, quite a bit. The water level looked fine, not overfill to activate pump. Door seals, wash arms all looked ok. Anything I maybe missing here?
Thanks for any help
Graeme
Not seen any crack (only diplomat ones) but they can become detached on one side, leaving the spray arm angled and prone to cause leak.
The other known culprit is the lower door seal.
Remove the outer door panel and see if the rubber “well” of the lower door seal is still attached to stainless. If it isn’t you would be best ordering 298534 and replacing it.
