When the dishwasher ends the wash it stops as it should but after a minute or so the drain pump starts up and you cannot get it to turn off. It will even run with the door open. Is it the control module?
normally means water in base pan operating flood protection system OR pressure chamber bunged up. I’d take the LHS panel off to have a quick butchers !
