Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › siemens dishwasher SE55531
- This topic has 4 replies, 2 voices, and was last updated 16 years, 8 months ago by
whistleblower.
August 26, 2009 at 12:37 pm #48090
whistleblower
ParticipantHi i have a Seimens 55531 gb/01 dishwasher which has developed a fault it has no LED display when switched on and does not respond to programs being selected.
so far i’ve checked the fuse in the plug its ok
removed door outer checked door catch mechanism seems ok all connected to main swith and sliding okany advice would be much appreciated.
mark
๐ฅ
August 29, 2009 at 7:42 pm #295547Penguin45
ParticipantRe: siemens dishwasher SE55531
Using a test meter, you need to check on/off switch function, then continuity from the plug, through the switch to the pcb. If you have continuity, the pcb itself will almost certainly have died. Worth checking the pcb for dry/burnt solder joints.
Stay safe, power off.
August 31, 2009 at 11:11 am #295548whistleblower
ParticipantPenguin45
Thanks for the advice i will check and re-post am i right in thinking the PCB is situated behind the program switches white plastic block?
The on-off switch has various wires, looking at them 2 black same terminal, blue purple, brown white, 2 red together could you advise which colour to check for continuity the purple and white wire are thicker and go to one connection block on the white plastic block (PCB)
mark
August 31, 2009 at 11:57 am #295549whistleblower
Here goes checking from the plug for continuity all connections in placeThick brown showing continuity to switch (feed supply)
Thick purple showing continuity when on-off switch is switched on
2 small red wires together showing continuity when switched on
Purple goes into a two port connection block with a white wire showing continuity on purple and connects into PCB
On removing the the 6 port connection block containing 6 wires one being the thin red from the on-off switch (at the PCB end), I lose continuity on 2 small reds at the on-off switch
Does this shed any light?Mark
September 2, 2009 at 2:34 pm #295550whistleblower
ParticipantDishwasher update I have removed the PCB part number Siemens 5wk57705 and carefully opened, on looking inside it looks burnt out on part of the board. I have been trying to source a new part but still looking, other Bosch/Siemens parts all look expensive around the ยฃ120 mark I am willing to replace this if I can find one.
Could I ask you experts for some advice please whatโs the possibility something else could have caused the PCB to blow in the first place, and replacing it whatโs the likelihood it will blow again? ๐ ๐ ๐ ๐ -
