Siemens dishwasher SE55M570GB41 not filling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens dishwasher SE55M570GB41 not filling
  • #43582
    boselecta
    SE55M570GB41
    Dishwasher not filling, good water pressure.
    Replaced inlet hose with self contained inlet valves (the aqua-hose), still not filling.
    The solenoid valve on the regeneration tank is humming, it has 240v going to it, I removed this valve and it is ok 3kohms.
    Has anyone else had this problem?
    thanks
    #277775
    Turbo
    Re: Siemens dishwasher SE55M570GB41 not filling
    Sounds like the module, have you got 240v at the fill valve?
    Graham
    #277776
    boselecta
    I can’t put my meter on the fill valve to test as its the fill valve encased in plastic moulding inside the aquastop.
    I dont think so as I can’t hear it being energised.
    #277777
    Turbo
    Should be able to get your leads on the connectors at the end of the wires inside the dishwasher cabinet.
    Sometimes the valve coils lose there resistance which damages the board 😥
    Graham
    #277778
    boselecta
    I dont think the inlet valves are getting power as these are new ones and still not filling.
    I will go back tomorow and check the board.
    Thanks for replying graham.
    #277779
    If regen valve is running this suggests machine detects that it’s already filled? Blockage of some sensor or other?
    Mike.
