Siemens dishwasher SN26M830gb/01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens dishwasher SN26M830gb/01
  • #79913
    winker
    This machine displays e24 on an intermittent basis but fairly regular.The drain pump has been replaced but in truth the fault remains.Now ive checked the heat pump because apparently e24 can be triggered by that,and it appears ok.Anything else i can check
    to cure this fault?
    The non return valve i read can be a problem so i will go back to check that.Any other suggestions appreciated.
    steve
    #411013
    Andy jones
    Re: Siemens dishwasher SN26M830gb/01
    Reed switch ??
    #411014
    winker
    well returned to the dishwasher,after five cycle starts lasting seven minutes a piece,i can confirm the following and hope this may prompt some replies.The machine cycles both the wash and drain pumps and proceeds to fill and circulation.On the sixth cycle start it runs the drain and wssh pumps but never started to fill…the solenoid on the valve never energised.E24 comes up and the check water tap symbol.Does anyone know whether the wash pump feeds back a signal to the microprocessor in the same way as the drain pump does.All advice welcome.
