Siemens dishwasher SN66L080GB/45
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens dishwasher SN66L080GB/45
  • #103686
    HotDog
    This dishwasher is leaking from the water distributor p/n00644996 it’s dripping from the white plastic section were the timer motor is mounted I assume the gasket to be the problem as anyone fitted one of these it looks like you would have to remove the base to access it
    #494203
    kaibart
    Yep heat pump off put a bit lubricant on the seal that comes with it it is tight to fit mind
    #494204
    HotDog
    Ok thought it was going to be job and half thanks for the reply
