Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Siemens dishwasher softener not working
- This topic has 4 replies, 2 voices, and was last updated 13 years ago by
AJLS.
April 10, 2013 at 2:41 pm #74962
AJLS
ParticipantI have an 11yr old Siemens SE65A560GB/42 that leaves a white residue on otherwise clean plates and cutlery which I am assuming is scale. I have replaced the filter inside the machine as the old one was broken/letting dirty water pass. I also replaced the rubber non return/flap accessible under a cover inside the machine. I then ran a descaler through on a hot wash. The plates are still covered in scale.
The water gets hot, the arms rotate alternatively (as they should) and are not blocked. The drain pump is working, and I have checked the water inlet filter and its clear.
I have just pulled the machine out and checked the Regen valve and the Heat exchanger drainage valve with a resistance meter – they both measure approx. 2.45k ohms – does this mean they are ok?
I notice on the plastic heat exchanger that there seems to be a blockage in the top left corner which looks like it may be a breather for the drain out? The drain goes up to the top and then down again presumably to get some otherwise wasted heat out of the water.
I also notice that the Air chamber level and pipe to the pump sump are dirty, a creamy colour?
I’m wondering whether to get this fixed, or just get a new one, it must have done 4000 washes. Do these only last 10 years anyway, or should it go on for 20?
Any help or advice would be greatly appreciated.April 10, 2013 at 3:32 pm #393415Martin
ParticipantRe: Siemens dishwasher softener not working
I take it the salt container is full and that the salt doesn’t dissolve through usage? If that is so then the salt regeneration valve needs replacing. Also sounds like you need to remove and thoroughly clean the fill matrix and away you go again a few more years! 😀
April 10, 2013 at 4:31 pm #393416AJLS
Thanks for you reply Martin. Yes the salt container is full and doesn’t get used up. I read somewhere on a forum that if the regen valve reads 2.45k ohm across the terminals, then its ok – do they only fail electrically, or can they also be mechanically caput?
April 10, 2013 at 5:05 pm #393417Martin
They fail mechanically.
April 10, 2013 at 5:24 pm #393418AJLS
Thanks, I’ll order one and let you know.
