Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Siemens dishwasher starts to fill then stops
- This topic has 6 replies, 3 voices, and was last updated 16 years, 1 month ago by
Scotmum.
February 13, 2010 at 10:08 am #52467
Scotmum
ParticipantDishwasher starts to fill but then stops. Does fill some water to base but does not turn the arms and wash the dishes.
Goes through program, drops tablet, etc but no wash is happening
Checked the flood protection – its not triggered. Help appreciated.
Was showing 1 minute left sometimes and not finishingSiemens S9VT1S
E nr. SE24T250GB/17February 13, 2010 at 11:59 am #311899nomadPaul
ParticipantIt sounds like the wash motor isn’t firing up or is seized. There are a number of possible causes.
1. Motor bearings seized
2.Motor impellor blade seized or blocked by foreign object
3.Start capacitor faulty
4.Start relay assy faulty.POWER OFF THE APPLIANCE – remove the right hand side panel and you will see the motor in the bottom left corner. . If you look into the end of the motor you will see some fins. See if you can turn these fairly easily.
If you can’t tun the motor/fins then it’ll be options 1 or 2.
If you can turn the motor ok , then it’ll probably be options 3 or 4.February 13, 2010 at 1:07 pm #311900Scotmum
ParticipantRe: Siemens dishwasher starts to fill then stops
Thanks, checked, motor can be turned but does not start at all. Capacitor looks OK visually, will check relay when we find it!
Thanks for the infoFebruary 13, 2010 at 2:57 pm #311901nomadPaul
ParticipantThe relay will be a small component on top of the motor itself . It sits where all the wires go into the motor.
The start capacitor may look ok but that doesn’t mean its working.
When the machine is started , and once it has filled up with water , is there a faint hum/buzzing noise coming from the motor ?
February 15, 2010 at 4:08 pm #311902Scotmum
Sorry for the delay in replying. We’d to wait till we got our meter back today.
Checked the start capacitor and yes, looked ok but it is dead.
Thanks for your help over the weekend. Will keep you posted on our progress.
February 22, 2010 at 8:25 pm #311903Scotmum
New capacitor in place. Dishwasher up and running for a fiver.
Thanks for all help in identifying where the various parts were hiding and how to get in to them.
Cheers!
March 8, 2010 at 12:13 pm #311904dsm24
Hi I have a similar sounding fault to this post. dishwasher takes in some water and the timer ticks down with the motor making noises, but nothing else happening. ideas?
