Siemens Dishwasher – water softener not working
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens Dishwasher – water softener not working
  • #46254
    Larkone
    Have a Siemens SL26231GB/12. It started to leave white residue over everything. I checked the salt level and topped it up but no change. Stopped using loose powder and started using tablets with salt and problem went away. However I have noticed over the last 2 months that no salt is being used even when hardness level is set to max.
    I am assuming that something (Valve?) is malfunctioning. Can anybody shed any light on this please?
    #288702
    Re: Siemens Dishwasher – water softener not working
    The regeneration unit is operated by a solenoid fitted down at the bottom of the left hand side of the fill/water level/resin chamber. It is possible that it has failed – a resistance check with a test meter will tell you. P/no 166875 if you don’t get a circuit through it.
    Power off if you’re going in……
    Larkone
    Many thanks for that. Will check and sort.
