Siemens Dishwasher with fan, heat pump fit.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens Dishwasher with fan, heat pump fit.
  • #97227
    subs
    Siemens integrated dishwasher
    SN66P050GB/01
    FD9503
    Changed lots of heat pumps on these machines by just lifting out Pc module to gain access. Now this one is the first I’ve come across that has a fan and venting into the cabinet that blocks access to the heat pump. Even the Pc module was difficult to get out as the space is so tight. I hadn’t allocated myself enough time complete the job so have to go back but was wondering if the only way to access the heat pump is to lift off the cabinet like the old Siemens, Bosch etc?
    Any help please?
    Subs
    #466598
    Hollytree_Technical
    I can’t say that I have done this particular model but on most of the integrated dishwashers I wiggle the pump out through the front of the machine – its tight and a little fiddly but usually fits and can be done with out having to take the dishwasher out.
    Jem
    #466599
    boselecta
    Hi mate,
    i queried this a on this forum a year or so ago.
    https://www.ukwhitegoods.co.uk/forums/forum/trade-member-forums/trade-technical-spare-parts-forums/trade-technical-enquiries/92516-s727p70y0g-11-neff-dishwasher-heat-pump-fitting
    Unfortunately it’s a case of taking the tank off the machine to replace the heat pump as side access is extremely restricted.
    Remember to factor this into the cost of heat pump next time.
    #466600
    subs
    Had a feeling this would be the case.
    Thanks for the info.
    Subs
    #466601
    twicknix
    Hollytree_Technical wrote:I can’t say that I have done this particular model but on most of the integrated dishwashers I wiggle the pump out through the front of the machine – its tight and a little fiddly but usually fits and can be done with out having to take the dishwasher out.
    Jem
    That’s impressive! I have never managed to wriggle it out from the front except for drain pump but not heat pump.
