I need a door seal for a Siemens WM14A260SK/04. The machine is on board a trawler and I think was installed in Norway. It looks like the model was not available in UK as I can’t find it listed anywhere. I wondered if anyone familiar with this make could make an educated guess as to which seal I need? The cabinet front goes right to the floor so there’s no plinth panel. Also the interlock is clipped on rather than held with screws.
Ta Brian, I did try that site but it said no results found. I’ve ordered an 18BS16 from Maddocks but I’m not sure if it’s in stock. It said “In Stock” on the website but underneath said it’s a special order :rolls:
I figured out what I was doing wrong on the e shop site (I had it set to accessories instead of spares) but I still don’t know how the numbers on the diagram relate to the part numbers as they are not cross referenced 😕
Phidom wrote: but I still don’t know how the numbers on the diagram relate to the part numbers as they are not cross referenced 😕
I dare say you’ve figured it out by now but if not you just click on the exact middle of the number on the diagram and the description and part number appear in a panel underneath which you have to scroll down to see.
Mike.
