Evening all , got a problem with a siemens double oven
model no – HB15N550B/10
FD 8804
Bottom oven fan not running , no 240v to it, is fault the selector switch or the pcb board , 1 wire goes to the switch other goes into the module , oven element heating ok
if theres any bosch/siemens tech online please help
Re: Siemens Double Oven – Fan not Running but oven heating
you will need to take wires off fan..check supply on each cable I suspect one will have power either pos or a neg..then u will be able to tell which one isnt feeding the fan & will know if its the pcb or selector.
Also I think you may find that the negitive feed links both the heater & fan (check 1st)
john
