Siemens Dryer WT36V398GB/07 Filter/Hose Light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens Dryer WT36V398GB/07 Filter/Hose Light
  • #82894
    Turbo
    This dryer cuts out after 10 mins with the filter/hose light flashing.
    It does this on timed and sensor programs. Filter and vent hose are clear and the heater is fine with no earth fault.
    Sensor plate in drum is clean.
    Front NTC reads 10K with the heater NTC reading 20K are these readings about right anyone?
    Thanks in advance
    Graham
    #421052
    nomadPaul
    Re: Siemens Dryer WT36V398GB/07 Filter/Hose Light
    You say the vent and filter are clear. Have you removed the heater and examined it to make sure that’s not clogged up with fluff?
    #421053
    Turbo
    Thanks for your reply Paul.
    Yes I did vaccum the whole machine including the heater which was quite blocked. Still giving the same fault though.
    The dryer has been heavily used.
