Siemens Dryer WT46E384GB/27 … Won’t start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens Dryer WT46E384GB/27 … Won’t start
  • #96125
    asp11
    This dryer will select any setting but just won’t start when you press the start button, it just bleeps
    I have visually checked all parts, connections and wiring, checked the pump area and all appears fine…. Any ideas please?
    #462429
    check door switch
    or child lock
    asp11
    Yeah, I’ve just found some posts relating to the door switch being a fault…. but putting a screwdriver into the lock does activate the microswitch???
    There isn’t a child lock on this model? Might it still be the door lock even if the microswitch clicks? Or is there a reset that may trick the pcb to operate it again?
    #462431
    micro might click but since its not carrying full current they still go faulty electrically
    asp11
    Alright, sounds like the trouble then, I’ll order one. Thanks very much
