siemens dw
  • #48108
    adv
    door wont lock. orderd new interlock. fitted but door still pops open mad cant adjust latch. checked for loose screws. an pulled it out from cabinet still doin it 😳
    #295590
    Re: siemens dw
    A Siemens dishwasher door lock ? 😕
    What’s the model number, that’s sure to help us take this further for you?
    #295591
    nomadPaul
    Check the top basket and make sure they haven’t clipped any cutlery racks into the wrong position – i.e too far forward – causing the door to not be able to close properly.
    Does it do the same thing with all the baskets removed ?
    #295592
    Re: siemens dw
    thought
    the hinges have not been strained causing door to pop open ?
    nomadPaul
    Re: siemens dw
    electrofix wrote:thought
    Thats a good thought Dave . However , its nearly never the actual hinges that fail but the door inner that gets bent and stops the door from closing properly. The door inner distorts right by the hinge securing screws causing the door to ‘twist’ .
    #295594
    adv
    Re: siemens dw
    yeh door al twisted wer srews are took outer door off still an tryed still same. an wi baskets owt 😳
    #295595
    nomadPaul
    If the door is twisted where the hinge screws are then it’ll need a new door inner mate.
    #295596
    adv
    Re: siemens dw
    ta
