Siemens DW door issues
  • #93362
    pmb
    Hi guys I have problems with a SN66T094GB/32 which keeps having the door latch go to the closed position but not locking the door closed. I have replaced the latch but intermittently does this. I can’t see anything out of shape on the door panel, the side springs are fine and it does this even with the integrated door removed. Has anyone had this issue?
    Thanks, Darren
    #454092
    Re: Siemens DW door issues
    have you checked hinges
    part no 165296
    smartin
    when door is open and in the down position, make sure there door isnt bent below the 45 degrees angle
    #454094
    blackandwhites
    If the appliance hasn’t been fixed into position properly, sometimes the closing of the door can push the whole appliance slightly back and so it doesn’t close properly.I have had that happen quite a few times.
    #454095
    pmb
    Thanks a lot, I will check all of this and let you know how I get on
    #454096
    blackandwhites wrote:If the appliance hasn’t been fixed into position properly, sometimes the closing of the door can push the whole appliance slightly back and so it doesn’t close properly.I have had that happen quite a few times.
    especially if the unit is under a granite worktop and they have fitted a wooden cross piece and then fitted the outer door higher so it hits it
    pmb
    Update on this if anyone else has this problem, the hinge bearings sorted the problem
    Thanks again
