Hi I have a Siemens SN66T097GB/74 which is flashing the tap and rinse aid lights, the PCB has no signs of damage so I have tried replacing it but it’s still doing the same thing.
Can anyone give me some advice?
Thanks, Darren
Thanks for getting back to me, it flashes along with the rinse aid light as soon as you turn the on off switch on.
I have had these lights flash before and replaced the PCB to fix it but not this time
The Tap symbol is the appliance way of saying fault encountered but no way of fi ding out what without running through a quick wash and seeing where it fails. 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time I find the heat pump to be the cause. This can be tested with the module removed just enough room to get test probes in and check for continuity.
