Siemens (E-Nr SE64M359GB/01) overfilling!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens (E-Nr SE64M359GB/01) overfilling!
  • #75637
    jonnyveeee
    Hi guys.
    I wonder if anyone could give me any advice on this dishwasher (SE64M359GB/01)
    The machine fills normally but then doesnt shut off & water then lifts the float to activate the pump.
    Is there a pressure switch on this model or is it a timed fill?
    Im not really clued up with the Bosch/ Siemens varieties!
    And another thing.. How do you access the base on these with no floor access panel. I can only get access from sides & front panel.
    Any help appreciated
    Jon
    #395704
    Re: Siemens (E-Nr SE64M359GB/01) overfilling!
    Float switch water level control, access via left hand side panel. Transfer pipe most likely blocked and needs removing and cleaning……….
    Please post technical questions in future in the correct forum (Trade Technical). Lots of info using the search facility. (Common to Bosch and Neff models)
    #395705
    jonnyveeee
    Thanks Martin. Will post in technical next time (didn’t see it when I looked for some reason).
    #395706
    jonnyveeee wrote:Thanks Martin. Will post in technical next time (didn’t see it when I looked for some reason).
    No worries.
    Do look up the thread “Tips, tricks and Shortcuts” in Trade Tech for loads of info on this including a .pdf download service manual….. 😀
    #395707
    jonnyveeee
    Will do.. Thanks again
    Jon
    #395708
    Moved.
    #395709
    jonnyveeee
    Just as an update to this post for anyone else with the same fault.. The problem was with the fill jug that measures the amount if water going in.
    Easy repair!
    Jon
