Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens E12 46 trips RCD on increasing spin speed
- This topic has 10 replies, 2 voices, and was last updated 11 years, 6 months ago by
hammy595.
October 5, 2014 at 1:02 pm #82489
hammy595
ParticipantSiemens E12 46 is tripping RCD when on increasing spin speed. Can anyone offer advice please.
October 5, 2014 at 1:14 pm #420049Martin
ParticipantRe: Siemens E12 46 trips RCD on increasing spin speed
Do please furnish us with the full model number(ENr number)…….
October 5, 2014 at 1:30 pm #420050hammy595
Hi thanks for the reply its WM 12E46SGB-22 just disconnected the earth to the motor to fault find (naughty I know) and it runs fine. Could it be carbon build up?
October 5, 2014 at 2:43 pm #420051Martin
Yes, dismantle and thoroughly clean the motor and replace the carbons.
October 5, 2014 at 3:44 pm #420052hammy595
Have now stripped and cleaned motor (very nice design can be totally stripped) and it still trips RCD and is (obviously) ok when earth disconnected, so do you think motor is u/s (short to earth), it looked all good when apart and runs fine when earth is off. I have a megger but not sure where to check motor, to avoid further damage. Thanks in anticipation
October 5, 2014 at 3:48 pm #420053Martin
hammy595 wrote:I have a megger but not sure where to check motor, to avoid further damage.
Using a Megger would never damage a motor. Usually the commutator is the problem so isolate and check that first (com segments to ground). Likewise the stator using the same method. Any reading less than 50 megohms will trip the RCD/MCB.
October 5, 2014 at 4:12 pm #420054hammy595
Hi stripped motor have checked commutator to ground (spindle) on m ohm scale and getting .01 and on multi-meter 200k range 26.0 this is on all segments looks like it is to ground to me but why all segs?
October 5, 2014 at 4:23 pm #420055Martin
The motor is knackered then (technical trade terminology) 🙁
October 5, 2014 at 4:36 pm #420056hammy595
Thanks so much for your help, have looked on here and sent a request for new one are they re-buildable (new armature) as it looks a quality item and is easily stripped by a novice ie me!!
October 5, 2014 at 4:58 pm #420057Martin
Not available in seperate parts (except the brushes). Has to be a costly complete motor otherwise. 🙁
October 5, 2014 at 5:36 pm #420058hammy595
ok, that is the same result i found,could be worse as some are more expensive and i can fit it,thanks again for your help.
