Siemens Electiric oven HB55055 GB01
fitted grill element about a month ago now as soon as the machine is switched on ‘ER4’ appears in the display and you are unable to set to any ovens.
The fault code in the book reads ‘temperture sensor fault call manufacture’.
Is this likely to be the stat or the temp sensor, also is there a reset procedure for this to get rid of the fault code?
thanks
