Re: Siemens FLA – F63 ERROR
Thanks for the reply Martin – I have since inspected the machine and found that the motor brushes were open circuit. It seems that the F63 error is ‘locked’ into the PCB because I have replaced the brushes and still get the error.
I think what i need now is to cancel the error code (or re-set the PCB). I have done this before on Bosch machines but the same method fails to work on this Siemens.
The buttons are the touch sensitive type.
Any help on doing a Siemens PCB reset anyone?
