Siemens Fridge Model No KU15RAGB
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Siemens Fridge Model No KU15RAGB
  • #65170
    m.haycock
    A loud metallic ‘clicking’ noise occurs when opening or closing the frige door. It appears to be from the lower door hinge. The door is stiff to open and requires a firm push to close. I gave a short spray with WD40 but no difference. The appliance is just over two years old and is subject to light domestic use.
    Any ideas or is it hinge replacement?
    #359365
    spimps
    Re: Siemens Fridge Model No KU15RAGB
    hould be able to remove plinth then hinge bracket which will have a spigot on that enters the door as the pivot,may just need a spacing washer adding.
