Siemens frost free fridge freezer.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Siemens frost free fridge freezer.
  • #6635
    I have a siemens frost free fridge freezer,while on holiday the in laws left the door to the freezer open,i have switched off appliance several times for up to 30 hours for it to defrost but no joy ,will try one more time for 48 hours,is it a expensive job if i call someone out what will they need to do.
    Paul
    #118763
    sparkey
    Re: Siemens frost free fridge freezer.
    You need to turn the appliance off for at least 24hrs with the door open or it will not defrost properly.
    After 24hrs wipe up any water inside and turn back on, all should be well.
    #118764
    Teddy,
    Won’t be able help you much without the model reference or “E. no”. If you can take out the crisper bins you should find a rating plate, the numbers will be on that.
    I have defrosted fridge freezer with doors open for upto five days several times but problem persists.The model is KG44U193GB ?.CAN ANYONE HELP.
    Cheers. 🙁
    #118766
    Dave_Conway
    Teddy, can you let us know exactly what the problem is please.
    You only indicate that the door was left open and you have tried to defrost it.
    Is it building up with ice very quickly or just not getting cold anymore ?
    #118767
    sparkey
    Teddy, as it appears that it has iced up several times since your first post in Oct. it sound like a problem with the defrost system, time for an engineer.
    Locate your nearest engineer on the ‘directories file’ over on the left of this site Or click on the tool box on the home page of this site.
    Regards
    Sparkey
    #118768
    Yes the freezer door was left open for several days while we were on holiday and now it builds up with ice in the bottom of freezer compartment ,i have defrosted several times for upto five days as it says to do but after a couple of days the ice builds up again.The fridge freezer is only 16 months old.
    Thanks for you help everyone
    Regards
    Teddy
    #118769
    Dave_Conway
    Engineer time then Teddy as Sparkey says 😉
    #118770
    superfix
    Sounds like a blockage in the drain channel tube that leads to the motor evaporator tray.
    clean this out,then turn off and leave to defrost.
    #118771
    Thanks Boro
    Have taken plastic pipe off and it was full of gunge like stuff and then put a wire up the tube but it would not go up very far so i didnt force it,but it must have done something as i cleared the ice out and it has not reappeared.
    Teddy
