Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Siemens grill element only half works
- This topic has 5 replies, 2 voices, and was last updated 20 years, 3 months ago by
piquet.
January 9, 2006 at 5:31 pm #14656
piquet
ParticipantHi,
I have a Siemens HB55065B built-in oven which is a touch over 2 years old. Just recently I noticed things weren’t grilling as evenly as usual, so I looked at the element while it was on. It appears that on the top level 3 setting only the outside of the element is working.
Is this likely to mean a new element or could it just be a bad connection?
Are they easy to fit?
Thanks!
Phil
January 9, 2006 at 9:39 pm #160350Penguin45
ParticipantRe: Siemens grill element only half works
That doesn’t quite make sense – it’s a single circuit grill element, so you should get heat throughout if it works and nothing if it doesn’t.
Can you please post the full eNr number from the rating plate around the door, may be able to narrow it down a bit more with that.
Penguin45.January 9, 2006 at 9:47 pm #160351piquet
Hi there – thanks for replying, and I’m really sorry – I got the model number completely wrong. I was at work when I posted, and looked it up on a spreadsheet I made when planning the kitchen – trouble is I bought a different oven!
Anyway, the actual E-Nr is HB760650B.
Thanks again,
Phil
January 9, 2006 at 10:06 pm #160352Penguin45
Now you’re talking. Double element, centre part almost certainly failed.
P/no is 471375, about £45 from memory, email to spares@ukwhitegoods.co.uk if you wish to order.
Ideally, you should meter the element to check its condition – power off of course. If you’re not sure, click the link below for a UKW engineer.
Penguin45.January 10, 2006 at 10:20 am #160353piquet
Thanks Penguin – I will order one, are they easy for me to fit? It’s easy to turn off the power, I have it on a separate circuit.
Cheers, Phil
January 10, 2006 at 10:02 pm #160354Penguin45
Couple of screws at the back normally and a bit of a wrestle with the support wire. Be careful not to let the wires slip back inside, or you’ll be dragging the whole oven out to retrieve them.
Penguin45. -
