Siemens HB131550B Trips RCD
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Siemens HB131550B Trips RCD
  • #17957
    JasonG
    I have a 2 year old Siemens Oven and this morning when I switched it on within about 10 – 15 seconds the Main house RCD Blew, I reset the RCD however the same happened again after about 15 seconds. I confirmed it was the oven after a few simple tests, and pulled the oven out and ran some basic checks (Short to Earth etc) using a standard multimeter – not a mega.
    It seems that – from reading posts on this forum – the main fan heating element may be faulty (happy to be corrected on this one).
    The question I have is will the heating element listed in the Shop@ section for Bosch, Neff and Siemens (ELE2044) be a suitable replacement as my model number is not listed on the page.
    The exact information on the rating plate is as follows:
    E-Nr: HB131550B/01
    FD: 8310 00273
    Thanks in advance for your help and advice
    Jason
    #177194
    Re: Siemens HB131550B Trips RCD
    Your element is p/no 443526, about £29 + VAT & p+p. It is not any of the ones listed in shop@.
    An email to spares@ukwhitegoods.co.uk for confirmed prices and ordering.
    JasonG
    Pengiun45 – thank you for your prompt reply, I have sent a mail to Spares as suggested.
    Is there anything else I should be looking at which may manifest the same fault – or is it likely that the element would be causing the problem.
    Thanks again
    Jason
    #177196
    If all other functions operate correctly; ie grill, fan, cooling fan, timer there’s not much else left to choose!
    JasonG
    Pengiun45, again your prompt reply is much appreciated – I will get the element on order
    Jason
