Siemens HB56M550B/03 double oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens HB56M550B/03 double oven
  • #98442
    WhiteVanMan1
    The oven fan motor doesn’t run through lack of supply. Element heats ok. There are two PCBs mounted on top of the oven, one of which I suspect is the problem. Which one is the question? One is listed as a mains board, the other just as a PCB which is the one I suspect. Both boards are visually good, no blown tracks etc, so I suspect a dodgy triac. Just looking for a second opinion really but any help greatly appreciated. Cheers. Steve.
    #472390
    diagram is showing muli switches behind the knobs
    have you traced the fan feed back to the source ? as it may be the switch
