Siemens HB750
  • #40705
    clayside
    Can anyone help with fault on Siemens HB750550B/02 OVEN
    After 5 mins of grill fault code 15 displayed,door is locked. Sometimes door stays locked even when oven is cold. Oven works OK on fan & normal heat, fauts happens only with grill.
    Regards Clayside
    #267290
    clayside
    Re: Siemens HB750
    Any help please. When full grill is on No 3 after approx 5 mins fault 15.
    have tried temp sensor but still the same. Seems to think oven is over heating. How is grill controlled is i timed via electronic or temp sensor ❓ Any help please.
    Regards clayside
    #267291
    Re: Siemens HB750
    Sounds odd to me that this thing locks the door on you. Maybe that’s a safety feature to stop you getting burned?
    I thought some oven/grill combos are meant to have the door left open when using grill. Have you RTM?
    Mike.
    #267292
    clayside
    Re: Siemens HB750
    Rang main dealer in area , he said grill with door closed. Instruction book no help.
    clayside
    #267293
    Re: Siemens HB750
    Just purely a guess from me but it wouldn’t be that the grill element has an earth leak maybe? 😕
    #267294
    gegsy
    Re: Siemens HB750
    Error 15 – If the actual temperature is above 380°C, the heating elements switch off and the oven is locked.The oven door does not unlock until the temperature drops below 300°C again. (appliances with pyrolysis)
    The error message is by deleted start from the customer service test program.
    If the temp is no where near 380, then I would assume PTC gone west 😉
    HTH
    clayside
    Re: Siemens HB750
    Fitted new PTC. This happens after grill has been on full setting for 5 mins, In service mode it dosn’t show any temp until door unlocks then shows 280 but can oven get to 300 in 5 mins? What controls locking of door is it PTC. The grill element stays on full red for the 5 mins its on should it cycle.
    #267296
    gegsy
    Re: Siemens HB750
    Possible a module or as Martin suggested earth leakage on grill element IMO
    clayside
    Re: Siemens HB750
    Will call back and check element,
    Regards clayside
