Siemens HB750550B/01 Fd 8511 Single Oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens HB750550B/01 Fd 8511 Single Oven
  • #103042
    rocker
    Called to check the problem. When the owner switched on it blew the rcd…Fault on screen (Shows E4 ) I checked the elements found the grill element has earth leak…disconnected….but when turned on can’t clear the fault code….any advice welcome..John
    #491578
    according to owners manual error 4 is temp sensor i would check that
    have you tried putting a load across the element terminals
    what i am thinking is you have to disconnect element to stop tripping but maybe computer is looking for a circuit
    rocker
    I will look into that cheers Dave..John
