Siemens HB75AB550B/03 oven Trips the rcd
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens HB75AB550B/03 oven Trips the rcd
  • #103432
    DPDOM
    The above oven trips the rcd as soon as the pcb relays engage but not on the light bulb setting.
    All components have no earth faults but things like the grill wiring and some microswitches are a dead short.
    I have traced this to the small power Pcb that has an earth wire connected. I can remember a similar issue I had years ago and replacing this board didn’t cure the problem
    Has anyone got any ideas
    Regards
    ignore microswitches
    ok assume the oven is turned off by a doubler pole switch. if not you will get odd readings on your meter
    if you connect the meter with one lead on earth on a high ohm scale do you get any readings?
    SWERV
    I am sure I have had this before on a Bosch oven and a Siemens oven and it was the control board that was faulty (the ones with the relays).
    Merv
    #493144
    DPDOM
    Thanks Guys
    Luckily I was able to pull the plug out of the back so no neutral was connected.
    Readings from the grill element wiring was almost a dead short and like I said all of the components checked out fine.
    PCB will be fitted at the end of the week so I’ll update.
    #493145
    DPDOM
    I fitted the new main Pcb and all is working
    #493146
    DPDOM
    The Big power Pcb not the small one.
