Siemens HB75RB550B/05 oven trips RCD
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens HB75RB550B/05 oven trips RCD
  • #87608
    cornwell40
    Meggered the oven and all elements etc test fine apart from the little power PCB. This has an earth connection but is otherwise insulated. From this pcb there are a couple of connections which appear fine but the 5 way connector to the large control?? pcb on the top of the oven when connected gives an earth short to the elements. Without the 5 way connected everything test fine.
    Ordered the small pcb (from Connect) but it arrived with a green packaging split label on it and the same fault. Thinking this was a dodgy returned faulty part I reordered….guess what, same fault.
    Anyone else had this or has anyone a suggestion other than bin it.
    Ta in advance chaps.
    TC
    #435398
    Re: Siemens HB75RB550B/05 oven trips RCD
    by the look of it small pcb is a power supply to the unit. cant see the earth cable on this causing the problem
    also the trip will not go unless you get over 30ma to earth so a couple of megs to earth is ok
    have you tried a long shot and connected the oven to another socket?
    cornwell40
    It’s a lot less than a couple of Meg…nearly a full short to earth:-(
    #435400
    if it were me I would disconnect all elements, fans and the lamp and see what happens then
    any luck did you find the problem?
    DPDOM
    Did you ever get to the bottom of this one?
    I have the same issue and also tried a new power pcb and still have the same problem. The oven turns on and interior light comes on but as soon as the control pcb relay clicks it trips. I thought I would see what happens if I disconnected the earth wire to the power pcb but one of the relays on the control pcb went pop.
    Anyone have any ideas?
