Siemens Hob error code ER26
  • #68722
    mackos
    Hi Guys Got a Siemens Hob to look at on Mon with error code ER26 anyone know what that relates to & a De Dietrich double oven that periodically cuts out whether in use or not & timer reverts back to flashing zeroes. I’m assuming this is possibly the thermal cut-out unless anyone knows different. Thanks Mack.
    #372569
    stevebunyan
    Not sure about the hob but as a starting point on the oven I would be checking the double pole isolation switch. I have come across a good number of these that have burnt out.
    Out of interest is the hob and oven at the same address?
    If so check they arnt on the same isolation switch as at full capacity the rating of the switch will be over reached adding to the possibility of burn out.
    Sent from Steves
    iPhone using Tapatalk
