siemens hydrosensor integrated
Home Forums Public Support Forums Help And Support Dishwasher Help Forum siemens hydrosensor integrated
  • #58069
    slyp98
    hi guys where can i find the model no. on this washer i have tried the door surround ,nothing on the kickplate or behind the side panels ? , when this washer is turned on ths outlet solenoid makes a lot of noise opening and closing rapidly , i changed the solenoid but it made no difference it still washes but the noise is unbearable any ideas thanks
    #333286
    nomadPaul
    It will probably be the pressure chamber/fill hose bunged up. This is sited on the LHS as you look at the appliance. If you can get to it and watch it , you may see the red float bobbing up and down as water enters the machine….it shouldn’t do this !!! The pressure chamber (The component the red float sits in ) and the ribbed fill hose leading from this into the sump , if blocked , will cause water to back up and operate the flood protection device ( The red float ) which thens shutd the valve off quickly and pumps a little water out.
    As to the model number , it should be chemically etched onto the top edge of the inner door and is quite difficult to see. It depends on the angle you look at it ! MAke sure the metal is clean or you won’t see ‘owt .
    POWER OFF AND PLUG OUT IF INVESTIGATING
    #333287
    slyp98
    cheers nomad , its not the antiflood i’m afraid , i m able to operate it by hand with the side panel off ,and then it shuts the solenoid off and pumps the water out but as soon as i put the antiflood back to its normal position the solenoid is off again shutting and opening in rapid sucession ?
