Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Siemens integrated dishwasher, possible failing pump?
- This topic has 12 replies, 2 voices, and was last updated 5 years, 6 months ago by
Manhattan24.
September 19, 2020 at 12:10 pm #98370
Manhattan24
ParticipantHi,
Unfortuntately my Siemen dishwasher (sorry, couldn’t find serial or model number around door or on front door) just decided to stop draining properly, so I bailed out the water and removed the impeller cover to check if it was blocked or had missing teeth, but looked fine. I then pulled out the rubber bit covering the valve and water poured out. Also, after unscrewing the lid on the salt compartment, water gushed out. I then tried the machine again, the pump sounded like it was working, but the water wasn’t filling. Any advice on whether it is fixable would be appreciated.
September 19, 2020 at 5:38 pm #472098electrofix
Moderatorbit confused now
start of the post you put
” just decided to stop draining properly”then at the end you put
“but the water wasn’t filling”and it cant be both
September 19, 2020 at 10:56 pm #472099Manhattan24
ParticipantSorry for the confusion. The dishwasher stopped draining at the end of the washing cycle, so I bailed out the water in the bottom and checked the impeller and valve. I then ran the machine for a second time to test it and no water pumped into it, but it sounded like the pump was making a noise.
September 20, 2020 at 8:24 am #472100electrofix
Moderatorthere is no pump to let the water in just a valve which in some cases can be difficult to hear
what your hearing is the drain pump so you probably still have a drain error
if the impellor is free and turning you need to checl for blockages elswhere
some dishwashers connect into the sink so remove the hose and put it in a bucket and see if it pumps out
September 21, 2020 at 11:53 am #472101Manhattan24
ParticipantThanks for the reply.
I found the hose and it does connect to the sink, I removed it and a small amount of water poured into the bucket. I then put a shallow amount of water into the machine, turned it on and it made the usual sounds, but no water came out of the hose. Perhaps it takes a while for it to start pumping out, or perhaps I’m not doing it correctly? Is there anything else I could try before giving up on it?
September 21, 2020 at 12:22 pm #472102electrofix
Moderatoryou have to cancel and restart a new programme a2 the first thing any dishwasher does is pump
Then see what happens
September 21, 2020 at 9:16 pm #472103Manhattan24
ParticipantI started a new program, and yes the water did pump out into the bucket, so I put the hose back into the connection on the sink and ran another cycle. I listened and water was definitely being pumped out and going down the drain. The problem was that the cycle didn’t seem to progress at all, just chugging with cold water sitting in the bottom and coming out of the spray arms. I left it to finish the cycle but it was in the same state as when it started, but seemed to be stuck with one minute left and not draining. I’m not sure if anything can be done with the machine now, but if there is anything else I could try, please let me know.
Cheers
September 21, 2020 at 10:03 pm #472104electrofix
Moderatorso is it running the programme but not heating then ?
September 21, 2020 at 10:09 pm #472105Manhattan24
ParticipantYes, the programme runs but hangs with one minute left and the water remains cold. Also, it doesn’t seem to be going through the cycle stages and is much quieter than normal, just a low rumble.
September 21, 2020 at 10:13 pm #472106electrofix
Moderatorthen in that case the next step is to check the heater
if you can use an ohm meter then thats easy but if it has gone it would mean changing the motor
September 22, 2020 at 9:08 pm #472107Manhattan24
ParticipantThanks for all the advice. Think I have got to the point where it would be better to put the cash towards a new machine, as it’s 8 years old now and I cannot locate the manual, model or serial number.
In regards to getting a replacement machine, are there any standout brands/models to look out for? I was thinking of going for a Miele, but not sure if it’s necessary to spend more if it does the same as a cheaper alternative.
Cheers
September 22, 2020 at 10:27 pm #472108electrofix
Moderatormiele is best in market for most appliances and is a lot better built than the siemans unit
September 23, 2020 at 12:36 pm #472109Manhattan24
ParticipantGreat, will go for a Miele. Thanks
