Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Siemens iq300 reset procedure
- This topic has 2 replies, 2 voices, and was last updated 9 years, 1 month ago by
RHrepairs.
February 10, 2017 at 2:04 pm #90572
RHrepairs
ParticipantChanged the brushes in this machine. Tried the usual reset procedure (6 oclock rpm button etc..) but to no joy. Has the procedure changed on these machines? Would the fact that its a rinse/spin at 6 clock and extra rinse is on that its not working? Help would be apprecuated thanks
February 10, 2017 at 3:56 pm #445242Alanj
ParticipantRe: Siemens iq300 reset procedure
Hi, found this after a search. Might be of help.
After fitting new brushes to a Bosch or Siemens washing machine you may be dismayed to find that it still doesn’t work.
Don’t Panic!
One of the following Reset procedures, depending on the model you have, will probably get the machine going again.
Reset Procedure 1, for a Siemens 16S series (WM16S) series machine after F43 error / Nulstilling af Siemens vaskemaskine efter F43 fejl (Thanks to https://madsdyd.wordpress.com/2014/12/0 … -f43-fejl/ )
Turn off the machine (dial to 0)
Open the door
Turn on the machine on first program
Close the door
Turn on the machine on the “six-o-clock” program, which is centrifuge
Press the “option down” button and keep it pressed (This is the button left of the display)
Turn the dial to “seven-o-clock” (empty/pump out program)
Release the “option down” button
Turn of the machine
Reset Procedure 2 (most commonly seen online, but not applicable to all machines)Turn the knob to off.
Close the door.
Turn the knob to 6 o’clock position.
Wait 2 seconds.
The start/pause should begin flashing.
(If the start button doesn’t flash, just carry on trying to erase the codes).
Press and hold the spin button. (it may be marked RPM)
Turn the knob to 7 o’clock position.
Wait 2 seconds.
Release the button.
Reset Procedure 3 for Bosch Maxx Classic washing machine
1. Close the door and make sure the dial is in the OFF position.
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the express 15 min program at the same time.
3. Hold the Start/Pause button for 10 seconds sometimes more.
4. Release the button and turn the dial back to the OFF position.
5. Select any program and the error should not be appearing.Alan
February 13, 2017 at 11:15 am #445243RHrepairs
