Siemens IQ300 SN26M890GB/28 Error Code 21
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens IQ300 SN26M890GB/28 Error Code 21
  • #82240
    spiralsmile
    Hi there,
    What does Error code 21 mean – as far as I understand its the circulation pump fault.
    Are they expensive and or difficult to fix?
    Regards
    tony
    #419260
    Re: Siemens IQ300 SN26M890GB/28 Error Code 21
    spiralsmile wrote:What does Error code 21 mean –
    Blockage in circulating pump.
    #419261
    spiralsmile
    Martin, is there a simple fix? Or is it a remove and replace?
    #419262
    Remove and check the impeller. If blocked then clear it, if impeller damaged then new motor best option.
    #419263
    spiralsmile
    Cheers Martin,
    Is there a good walk through of the operation out there?
    #419264
    spiralsmile
    Ye olde, hosepipe! Where would we be with out it. Shoved it up the circulation pump inlet with tea towel to seal it. Ramped up pressure and this has seemingly solved the issue without removing anything.
