Siemens iQ700 access to change dampers
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens iQ700 access to change dampers
  • #101013
    paclx
    Hi. My Siemens iQ700 is showing signs that the dampers are worn. Loads containing mainly clothes, that can distribute evenly during spinning, are fine. Towels and sheets are a problem and it takes ages for the machine to get them in balance for spinning, with lots of banging and the machine moving across the floor. The feet are correctly adjusted and the machine is level.
    How do I access the dampers for replacement? From the back, bottom, front, or all three?
    Hugh
    #483008
    whats the full Enr number ?
    normal access from front but need number to check
    paclx
    Thanks Dave. The E-Nr is WM16S890EU/14 FD 9205 00448
    #483010
    take rear cover off and you should be able to get rear left and the one on the right
    to get front left you may have to take the front off
    paclx
    Thanks Dave. Rear access looks to be fairly simple. Front may be more of a challenge. Any tips?
    Hugh
    #483012
    not as hard as it look
    you have to remove the door seal front clip
    on some machines the control panel has to come off
    but take care and time its fairly easy
    paclx
    Thanks. Is 00742719 the correct part number?
    #483014
    paclx wrote:Thanks. Is 00742719 the correct part number?
    not as far as i can see
    all siemens spares can be looked up here
    https://www.siemens-home.bsh-group.com/uk/customer-service/spare-parts-search
    part no I get is
    11039636
