Siemens IQ700 – Error E24
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Siemens IQ700 – Error E24
  • #97532
    Matt_Bianco
    My dryer comes up with this code intermittently, but seems to happen more with bigger/heavy loads.
    Any ideas? I did read somewhere on google it was suggested a PCB fault. I can repair to component level so any pointers much appreciated.
    Many Thanks,
    Matt
    #468278
    whats the full Enr number and FD number ?
    I only found 1 ref to this error and it seems to be a board or software problem
    described as “Control fault 1″ ” process software set is incorrect programmed ” ” update software or replace control ”
    Matt_Bianco
    Thanks Dave, E-Nr is WT48Y801GB/09 FD 9311 200578
    #468281
    ok that gives me an age, it was built Nov 13
    think the fault code i found is likely correct but siemans tech is hard to find
    Matt_Bianco
    Hi Dave,
    I’ve done a bit of googling and found that my dryer seems to have the same control board as the Bosch Home Professional WTY88700AU/07 (same test mode too) which according to another site mentions this is Bosch T24xi. They host a service manual for this model but of course it’s not free and you need to be in the trade etc.
    Not sure if this helps?
    Cheers,
    Matt
    #468283
    where i got it from is one of the manuals hosted on manualslib which is a free site. you will never get an exact match but you have to hope some error codes wont change otherwise their own engineers could not remember them
    Matt_Bianco
    Quick update, seems the fault may now be fixed. Fingers crossed.
    I removed all three control boards – display, inverter and main control. Resoldered all pins on Inverter IC and blanket solder the rest of the caps etc. Cleaned all connections and re-assembled. The good news I saw all Rubycon electrolytic capacitors throughout! 🙂
    I’ve since found that Error 24 below:- [TABLE=”border: 1″]
    [TR]
    [TD]Compressor / inverter communication error[/TD]
    [TD]DBUS connection disconnected, inverter is not switched on, inverter defective[/TD]
    [TD]Check the cable to the inverter, check the inverter when the program has started[/TD]
    [/TR]
    [/TABLE]
    Cheers,
    Matt
