Re: Siemens KG29 Fridge not cold
tank_joe wrote: Is there a way of indexing problems/solutions to save wading through hundreds of topics?
They are indexed in a database, use the search function 😀
Getting to your problem though, as this is a frost free unit it’s one of a few things:
Defrost problem blocking the air flow, as you say, the fridge relies on cold air being “blown” up there from the freezer.
Fan motor failure
Compressor failure
Short of gas
Ask for a second opinion, the original engineer could be correct, if the compressor is failing and there isn’t sufficient “pressure” or gas being pumped it could well cause this problem.
And don’t saw it up eh, that’s just silly 😉
