Siemens KG31V20GB – not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Siemens KG31V20GB – not cooling
  • #37921
    telemek
    on checking this fridge/freezer there is no cooling but if power off & back on gets to temp fine but cuts off not to restart. Maybe something to do with a NTC sensor? Any ideas
    #257126
    Simon46
    Re: Siemens KG31V20GB – not cooling
    There is a modification available. http://www.ukwhitegoods.co.uk/modules.p … hlight=kgv
    Power off if you are going in. Or Repairs@ for an engineer.
    Regards
    Simon
    #257127
    telemek
    Simon
    Thanks for your reply, I will try the by-pass later today & let you know the result.
    regards Graham
    #257128
    telemek
    Good morning
    Tried bypassing sensor as per previous post (shorting dark blue & brown wires) but same fault, re-connected & bypassed other sensor (light blue & black) and checked temp after 12 hours and everything to be working fine. Will update if any problems.
    Thanks for your help.
