siemens KG39NH90 compressor relay
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemens KG39NH90 compressor relay
  • #91342
    char14lew
    FD 910100135
    The relay on this machine is producing an awful burning smell.
    Tried to source a replacement and siemens have made it only available with a new compressor- £207……….great!!!!
    part number on relay is 100929 with TY-QZ-108 J14 PPS written above it.
    Does anyone know if there is a universal replacement please?
    much appreciated
    Darrell
    #447786
    RocketMan
    Re: siemens KG39NH90 compressor relay
    Full model number required.
    Search here http://www.siemens-home.bsh-group.com/u … pare-parts
    You’ll need the last bit of your model (Enr).
    Possibly part no 00618375 but please check.
    Make sure it’s the relay/starter that’s smelling. Different compressors, some have run caps. Good luck
    #447787
    char14lew
    Thank you matey, I did go on the siemens site, I scrolled through but couldn’t see a relay other than the full compressor kit!
    that p/n you supplied is indeed the correct one. I checked the capacitor with a meter and is good!
    thanks again Darrell
