siemens microwave E1006 error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemens microwave E1006 error
  • #103425
    suedehead1
    Siemens microwave BE634LGS1B/03 , I normally don’t touch them but the day after I fixed their main
    oven customer complains about the microwave coming up E1006, i checked all the connections and it seems ok.
    it works on the grill function but on microwave it runs for about 5 seconds then switches itself off or shows E1006.
    I saw a post on here about a neff oven with same fault and was wondering if anyones managed to repair this fault
    and obviously what neeeded done any advice welcomed.
    #493119
    kaibart
    Magnetron failure that error code is probably been using full power to re heat food
    #493120
    suedehead1
    thats great thanks very much, its certainly cheaper than a circuit board definitely worth a try
    #493121
    here is a similar post where Kai has posted the fault code explanation
    as for the mag you can use Gen or contact
    https://magsells.co.uk/
    ignore the website prices as they do it cheaper for the trade. should get the mag for under £50
    https://www.ukwhitegoods.co.uk/forum…or-code-e10-06
    #493122
    suedehead1
    thanks very much cheaper than the genuine one
    #493123
    suedehead1
    I decided to go with a genuine one from connect so i could send it back if it didnt work.
    fitted new magnetron and it worked ok, thanks for all the help.
