Siemens Not finishing wash cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens Not finishing wash cycle
  • #10375
    I am having a problem with my siemens dish washer, it does not appear to be finishing it wash cycle all the time. Some times it it gets stuck with 1 minute to go and the dishes are still wet, as if the drying cycle hasnt run. I have checked the filter in the Aqua Stop filter and that seems ok. The problem also seems to be worse on the Auto sensing cycle rather than the fixed cycles. Another aspect is the times for the cycles seem to be shorter than they use to be.
    I guess that one of the sensors in it has failed, but any suggestions as to which one would be welcome. Also are there any diagonstics that I can do on teh control pannel .
    The only numbers I can find on it are 5600040998/03/056/15:21 on teh back bu teh power cable and 1732 388 672 on teh plastic above teh door
    #139698
    Dave_Conway
    Re: Siemens Not finishing wash cycle
    I would suspect a partial blockage in the drainage somewhere.
    Check where the waste hose meets the sink trap (assuming it does) as this is the most likely place.
    Apart from that, we will need the correct model please, it begins Enr and will be on the sides of the door itself normally.
