Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Siemens Oven door inner glass
- This topic has 5 replies, 2 voices, and was last updated 15 years, 7 months ago by
gladstonescrewer.
August 31, 2010 at 8:27 pm #56913
gladstonescrewer
ParticipantCan someone tell me of an easy way to remove the inner door glass to a Siemens, Neff, Bosch oven door. Once you have unclipped the outer glass, the inner glass sits inside a frame and each corner is held in by a springed-clip. It looks as though you need four hands to hold back each of the clips and then another set of hands to remove the glass.
There must be an easier way. The model number is HB91554GB/06.
September 1, 2010 at 7:45 am #329253Martin
ParticipantRe: Siemens Oven door inner glass
I suspect you may be in the trade as your previous posts refer to various other ovens and cooker hoods. Why then don’t you apply to join as a trade member in order these questions be answered?
More info HERE. 🙂
September 1, 2010 at 4:40 pm #329254gladstonescrewer
I did not know about this so I will look into it….
However, why would or should I have to join as a Trader in order for questions such as the ones I post to be answered? I don’t think I’m being unreasonable?
September 1, 2010 at 5:00 pm #329255Martin
gladstonescrewer wrote:I don’t think I’m being unreasonable?
Not in the least my friend but I’m merely suggesting to you that if you ARE in the trade then your question and more can easily be accomodated by being registered as a trade member. Your choice, I’m merely pointing you toward a better solution on the assumption, on my part, that you are in the trade?:?
Sadly on your specific question I don’t know the answer. I would however politely suggest that you ensure the door is fully removed from the appliance and laid on a flat surface before unclipping the 4 clips. 😉
September 1, 2010 at 5:52 pm #329256gladstonescrewer
September 2, 2010 at 6:57 am #329257Martin
