Re: Siemens Oven – HB55055gb/01 error 4
You either have a faulty oven PTC or an electronic unit fault within the temp measurement range.
The sensor readings are as follows –
Temp in deg C /Ohms
0 = 500
50 = 590
100 = 680
200 = 870
500 = 1400
Er4, Would have the following reaction to the appliance. It does not heat up, fans switch over to run-on. Following correct temperature measurement, the fault is cleared and the cooker heats up again.
HTH
