siemens oven HB770560b/ 02 front glass replaced
Home Forums Public Support Forums Help And Support Cooker And Oven Forum siemens oven HB770560b/ 02 front glass replaced
  • #87059
    Innocent18
    hello forum,
    the story is as follows, we had the siemens oven on clean mode and the exterior glass exploded, i have now replaced the glass but while oven light comes on there is no heat from the oven or grill, all the controls and digital numbers are working but nothing is happening
    #433847
    Re: siemens oven HB770560b/ 02 front glass replaced
    if you had the mains off did you set the clock properly as most units default to off
    Innocent18
    i have set the clock, it does everything but there is click when you press the ok button
