I have a Siemens single oven HB75AB550B/01, six years old.
This morning, when I turned the knob to switch on the oven,
there was a flash on the display panel and the RCD tripped.
I switched the oven off at the wall and reset the RCD.
Now, whenever I switch on at the wall, there is a flash on the control panel and the rear fan starts up immediately and stays on, even though the control knob is still at the off position.
When the knob is switched on there is no heat from any element; the oven light does not come on and the display panel stays blank no matter how I turn the knobs or or set the clock buttons.
The RCD has not tripped again.
I’m assuming this is going to be an expensive repair. Is that right? Which parts will I need to replace?
