Siemens Oven overheating HB760550B/02
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Siemens Oven overheating HB760550B/02
  • #101572
    roybun
    Oven overheated badly burning food. Checked sensor (part No 00423842) which gave a reading of approx 550 Ohms. Is this likely to be the problem?
    TIA
    #485294
    siemens dont give out tech info too easily so we dont know what resistance the probe should be
    if you set it at the lowest temp does it still overheat massivly
    roybun
    Dave. Thanks for the response.
    ‘if you set it at the lowest temp does it still overheat massivly,
    Yes, it overheats massively at both normal and air setting even when set at 40 deg C.
    #485296
    first thing i think i would check is the relays on the board. If the one that controls temperature is welded closed it will cause this fault
    roybun
    Thanks Dave
    I was hoping it would be a simple fix, like a new sensor. Seeing as the oven is 15+ years old I’ll just scrap it.
    #485298
    try one big long shot
    find board and firmly tap each relay
    then try it
    if it works it was a stuck relay and it may happen again or it may not
    roybun
    Thanks again Dave.
    I hear what you are suggesting, but we decided to cut our losses. New oven being delivered tomorrow – not Siemens!
    #485300
    as long as its not one of the cheap makes will be ok
    roybun
    Miele – it cheap!
    #485302
    roybun
    Not cheap!
